Also look at the red circle, in the first set it is much wider -- which is correct? And on the rudder bars, should all three bars be the same width or is it customary that the red bar be wider to conform to the aft section of the rudder? I plan on having sheets made with crosses of three sizes for fuselage, upper and lower wings along with rudder panels that can be cut to conform to a wide variety of aircraft rudders. Once these questions are resolved generic sheets will be made on an ALPS printer at a very reasonable cost if anyone else is interested in acquiring some. For me there are just too many Romanian subjects I want to model and no readily availible good quality graphics availible. While it is not visible in the scan there is a white boarder around each cross.
Aceasta postare a fost editata de Swanny: 23 September 2005 - 06:12 PM
